- Aug 20, 2024
- 31
Hello all. Brand new to metal lathes. I am making my first attempt at threading, but Vevor’s manual is next to worthless for any kind of explanation or guidance. My lathe came with the metal change gear set. I thought I’d try making a 1/4-20 bolt. The manual and the label on the case say the gear setup needs to be a 40-tooth on A, a 65-tooth at B, nothing a C (?), and a 55-tooth at D. There are no 65 or 55 tooth gears in the set or even on the lathe. Somebody out there must have this model and has figured this out. Help!
Thanks y’all in advance!
