I asked a week or two ago about change gears for my 1946 leblond. Since the gears on the Leblond are a defunct 14DP gear, I have decided to change it out to a more standard 16DP gear set.
All of the gears from boston are 1/2 thick 3/4 bore. The bushing the gear runs on in the adjustable quadrant is 3/4 diameter so everything fits perfectly there. However, the drive gear shaft and the QCGB shaft are 11/16 diameter.
What would be the best way to fit the 3/4 bore on the 11/16 shaft? I would think a thin adapter sleeve would be too thin at 1/32 wall. These are not friction surfaces, so this may be ok, but might be a little difficult to make with my current abilities. My other thought would be to bore the gear out and then make a thicker adapter bushing.
I would prefer not to modify the actual lathe and just modify the auxiliary parts that fit on it.
Any other thoughts?
Any other thoughts?
