The sheet is 2 mm thick. I need to cut out a plate taking the shape of several arcs combined so end mills is the only tool option for me. I have tried 2-flute 5 mm end mill which is OK but the amount of materials removed seems to be more than necessary. If I go for smaller diameter end mills, chip evacuation will be a problem. Will roughing end mills be better ? 4 flutes or 2 ( haven't seen such type ) ? what diameter and RPM will be optimum ?
