- Nov 27, 2012
- 7,912
I have a cheap HF 1 ton arbor press that I've had for a while. It's one of those things that I don't use often but need/want. I need a bit more working height though. As much as I would love a Famco or Dake I can't afford one & wouldn't drop that kind of cash on something I don't use often so an import will do just fine. No hits on Craigslist, been looking for a while now.
I'm looking at a 2 ton & 3 ton ratcheting. The 2 ton has a max working height of 8-1/2" & weighs about 115 lbs. The 3 ton max work height is 12-5/8" & is about 170 lbs. The one I have now is only 5-1/4" and is 40 lbs.
I'm leaning towards the 2 ton because of weight. It's for my home shop & I don't have a permanent location for it so I'll have to lug it around whenever I need to use it. I was thinking of just getting a bench grinder stand like one of these & mounting it on top of a plate whenever I have to use the arbor press, grinder, buffer, or bench drill press, then I can store away when done.
But I was reading that the 3 ton just barely has enough room to do some broaching. I never had to broach something yet but if getting the 3 ton means I can later then I might as well spend the little extra to get it now. But damn 170 lbs is not something I look forward to moving, not sure if I even can safely, and if even one of those cheap bench grinder stands can support it.
I can get the 2 ton from Amazon for $212 shipped + tax. The 3 ton I can get from MSC for about $250 + tax, no shipping cost cause I have a local MSC outlet. I might even be able to get a bit better discount when I go in.
What do you guys think based on my situation?
