Need a dimension from a PM-1030V owner for my stand design, please
xtphreak
Sep 29, 2022
4
I'm planning (slowly) to get a PM-1030V on order soon, but I need to complete a stand so I have somewhere to mount it.
I need the height of the cross-slide wheel axis from the plane the lathe is mounted to.
My intention is to design the lathe stand so the lathe cross-slide wheel is about my elbow height once it's mounted.
Anyone with a measuring device want to assist?
I have a 10-30, but its in Ohio and I'm in the Netherlaands.... Sorry, If when I get back,, (Mid November) you don,t have an answer, and I remember, I;ll get it fir you. (typo's due to a damaged fingerf.)
I can & will measure this for you at 9:00 AM PST.
I appreciate the offer.
I'm on nights this week, one out of 8, so I might not see your reply in an expeditious manner.
PM says their stand is 30" off the floor, but my elbow is about 43" off the floor, so it seemed a little low.
Thanks in advance!
Ron
Hope it's not your "digitus mediaus".
You know, the one you use to convey social antisocial messages.
Ron
The axis of the cross slide handwheel is 38-3/4” off the ground. I have a PM-1030V factory stand, & the surface that the lathe mounts to is 30-5/8” as I carefully measure it.
Hence, the answer to your question is 38-3/4” less 30-5/8” to get 8-1/8”.
I did a sanity check via a direct measurement, & I also got 8-1/8”.
Now I have carefully triple checked, & it is 8-1/8”. Put it in the books!
FYI I am 5’, 9” tall with a 32” inseam, & for me the cross slide handwheel really is *right in the sweet spot* for my comfort as positioned in the measurements above.
I also have a PM-1660TL with a factory stand, & the axis of it’s cross slide handwheel is 38-1/4”.
