- Aug 22, 2021
- 42
Need some help identifying what I am looking at. I decided to clean and adjust the gibbs and at least look at and try to tighten the nuts all I could get by with and then I came across this nut support deal with no adjuster on the x axis, presumably on both axis. Threads has a lot of wear middle compared to ends. Has someone converted this machine to ball screws. Or. ??? Kinda hard to see but that is an oil line sweeping up and going into the nut in the approx. area where you would look for the nut retainer and adjusting screw. See pic attached. I really want to tighten this machine up, might be looking at both screws and new split nuts with a support.
