- Oct 28, 2014
- 23
So I am trying to make my own rotary table for my mini-mill - a fun project. Its a small table as the mill is small - just 4 inches.
I got from the scrap yard a block of steel that was around 4 inches in diameter and maybe 4 inches long. The block looked like something used to be rolling on it - maybe part of a roller in a chassis of a large machine such as excavator - there were many similar looking parts around. So for few dollars I got my steel.
The lathe didn't have much of a problem turning the steel through I did get a carbide disposable bit dull. After turning it and getting it to shape I had to slice it in half as obviously I didn't need a 3 inch high rotary table surface. The band saw is 5 by 4 with stock blade - I got it to cut the steel but for some reason it cut at an angle with blade angling to the inside - even after making the blade very tight.
Back on a lathe I fixed the off-cut and time to mill.
And here is where issues started...
I was planning to cut 4 short rows 1/2 inch wide and then use a T-cutter for a slot. So I placed my 1/2 inch rough end-mill from HSS and just set it for 10/1000 of an inch 1/4 of a mm. Well, this is strange, instead of cutting the steel the bit "polished it"!
So I assumed the bit is just dull and got a 3/8 inch brand new HSS. It cut great for about 120/1000 maybe 3mm and then high end pitch sound made me realize its dull already - after cutting about 1 inch long row by 120/1000.
So I took out my beaten up carbide 3/8 which has only one tooth left - I broke the others off as I was playing around with it. It cut great for about 6/10 of an inch - then I switched to the other row and it got dull.
Well, I know my piece is not a high carbon one b/c the band saw cut it off... but it is clearly not so soft stuff...
So what am I dealing with?
