Check out my Myford Clone lathe that came with Faceplate, 3 and 4 jaw, fixed and travel rests and an extra set of change gears for cuting threads which include the metric set Works awesome!
I picked it up in Hamilton Ontario from a high school shop teacher three years ago for $350 cad. I guess you could say i stole it I had an old New Hudson lathe made in NY before this one and before that had a 1913 Seneca Falls lathe. I moved and the Seneca was too big for my shop so I sold it and a #2 Van Norman mill for $1500. I wish I still had them both. This Myford Clone has made a lot of chips this year as i used it to machine parts for a couple of reciprocating hacksaws that a friend from Florida designed and we built them in August. I'll post some pictures.
Hi, I have the same lathe, 7x20"
I was thinking of getting the 127 tooth gear to cut metric threads as am starting to cut quiet a few. Do you have that setup?
Cheers,
Zee
