My Tangential Tool Holder
Holt
Machinist
Mar 16, 2016
40
After reading so much good about the tangential toolholder i decided that should be the first "real" tool for my Colchester.
I started with a piece of unknown tool steel 25 X 43 X 140 mm
I couldn't find the angle base, so i decided to try the magnetic sinus plane, a bit scary, but with light cuts it went well.
Suddenly time ran out (typical when you are having a good time cheesy.gif) I had to collect my son from sax practice.
I didn't have time for the last finishing touch, not even for deburring, but at home i made a trial fit in the lathe.
Well, next Wednesday there is 3 hours to kill again, i would think that should be more than enough to finish it grin.gif
Well... i couldn't wait until next Wednesday to finish it, and since i don't have a mill at home, i just had to use the lathe.
I cut most of that ugly edge with a angle grinder, the rest with the lathe
I turned drilled and treated the two holding clamps
Then i milled the recess
Perfect fit
The upper clamp was outside the tip of the tool, and had to be milled a bit
I am quite impressed with the first cut, this is a piece of stainless
Now i have to build a tool grinder, and a grinding fixture grin.gif I am really looking forward to use this tool
I am sure you will like it...... I made one a few years ago and I use it often. Once you make a sharping jig it only takes a minute to touch the cutter up on a bench grinder.
I must admit, I made this writeup some time ago, and have been using it a lot. I have been wondering if it would be possible to grind the toolbit with a radius, so the cutting edge and the opposite edge are the same height, that would make it double sided .
I just wanted to add some basic dimensions to the tool in case someone want to copy wink.gif
I am sure that the most here are capable of filling in the blanks grin.gif otherwise feel free to ask
That deckel mill sure looks nice. They seem hard to find around here if ya do it's pricy. Like the tool ya made hope I can try one out of my own. Good luck with your lathe it's a nice machine after you fixed her up.
That Deckel is a beautiful machine, it's one of the very lovely machines we have at work, unfortunately it's from a bygone era, where you could buy high quality manuel machines, last time I was on exhibition to Hannover fair, the only manuel mills there was made in China, don't get me wrong, I have nothing against Chinese machines, but there is a long way to the quality of the Deckel.
They are very pricey around here as well, when this machine was made, Deckel was considered the Rolls Royse of manuel milling machines. We have a Deckel FP1 from the sixties as well, a machine as that comes with a price tag of about $3000. EDIT I just looked at ebay Germany, the cheapest came in at about $6000.
I never made a jig for mine, I just eyeball the angle on the grinder.
I haven't made a jig either, I still have to try to grind the cutting tool with a radius, so I have two cutting edges in the same end
