- Jan 1, 2018
- 1,333
Yes, I know most woodworks think a Radial Arm Saw is an extinct tool with no use in a modern woodshop. The first cut I ever made with a power tool was on my fathers Delta 10" turret arm radial arm saw when I was about 10 (under his close supervision). I assisted him ripping boards and sheets many times on that same RAS as we did not have a table saw. The very first stationary power tool I owned was a Craftsman RAS which didn't last very long before upgrading it to a Dewalt RAS.
Today I brought home what I believe will be the last RAS I will ever purchase. A 5hp 16" long arm Delta turret arm RAS:
I have been VERY content with the 1947 16" 7.5hp Redstar RAS that I have been using for the past 25+ years:
But the new RAS was just too good of a deal to pass up at $100 for a long arm RAS. The Delta has a 6" longer arm allowing for 6" longer cuts. I have some work to do on it before using it. The wiring has very brittle insulation around it and the handle for the turret stop plunger is broken off but both are easily fixed.
Redstar was the original company that made the Multiplex turret arm RAS before WWII and were bought out by Rockwell in the late 40's who took over the design. I am going to have a very hard time parting with the Redstar having used her on pretty much every woodworking project in the past 25 years. Part of me says it is time to let her move on to make room but another part of me says to keep her as I will never find a saw so cool again.
