My little 400 all cleaned up...
Bellwether
Apr 7, 2013
62
I picked up a little 400 a few weeks ago and was off this week so I decided to tackle cleaning it up. It was all pretty straight forward, no snags or anything and all I had to replace was one bearing that had a hole in the shield. I still need to clean up the motor and mount and then learn how to use it! Here are a few pictures...
Nice job! She cleaned up real nice.
I'm not that familiar with the 9" Logans but I assume that the bearing you replaced was a spindle bearing? Was the bearing bad? Sometimes a small hole is put in the shield just to add grease to an old, good bearing. Just curious.
Steve
Nice job on the cleanup and paint, It should do a good job for you.
Paul
Stunning. How did you get that headstock label to clean back up? Also, I loved the generous use of the red as well, really made it pop!
Steve
Thanks for all of the kind comments, fellas!
Yes, it was a spindle bearing. The hole in the shield may have been there for that purpose, but the bearing was trashed. It was dry, loose, and had lots of grit in it, it really did need to be replaced.
Thank you! the badge was actually pretty easy to clean since whomever painted it that silver color painted over all of the grease and oil. I just hit it with a scotch-brite pad to get most of the paint off and then used a toothpick to dig the paint out of the nooks and crannies.
