Well I picked up my mill today, I got it from my dad along with a South Bend 9A lathe
Is it worth fixing up or is it just junk?
not bad for a freebie in my opinion
Another nice machine, especially if it turns out nice like your SBL.
That mill you have there will have me shopping...
Looking forward to the "after" pictures as well.
Well i got it home and unloaded, that thing is HEAVY! not much fun to move by myself. I got it to the door with the Kabota tractor then had to maneuver it thru the door and across the room. I had to sit down and have a beer after that one. But anyway I got it in its spot. I started wiping off some of the grime. it hasnt been cleaned for a very long time, (dad isnt very good at that) Here are a couple pics
when im done fixing up the lathe this will be my next project
I didn't have much luck in finding information on mine either, but Grizzly still sells the same machine with a few minor changes. It looks like yours should be the same as the G0728. http://www.grizzly.com/products/Vertical-Mill/G0728?utm_campaign=zPage The newer version has a one shot oiler system, but not many other changes. It looks like your mill has had a column extension added.
