- Apr 23, 2011
- 2,476
For those members that may be considering melting metal for fun, it can be a fairly straightforward and simple process to build an effective furnace.
Let me state first, I am not going to get into a bunfight over safety concerns with the materials used. Appropriate safety considerations and precautions were applied during construction.
Mine is an old LPG cylinder cut down for the main body and then the lid was cut off the remaining portion. It is lined with about 50 mm of Kaowool and has a roughly 40 mm thick castable hotface.
A homemade (not my design) oil burner enters tangentialy at the bottom. This design will melt about 2 lt of liquid ally in 30 minutes from a cold start or 10 once everything is hot. Brass & bronze takes about 30 minutes. Other people have used similar designs and can melt cast iron with theses types of set ups. I havent tried CI yet but I think i might get close.
I get my scrap ally from engine/gearbox parts, alloy wheels, old broken cast alloy parts and pieces. Pretty much anything that was cast once makes a good base product. Ally cans do not.
Scrap brass from various sources, taps are good, but lots of dross. Old propellors, bushes, boat bits. Sometimes I will buy from the scrappers if I want good bronze.
My burner runs on waste oil from, mainly sump oil, but pretty much any old oil will suffice, waste vegetable oil is another source that I havent tried yet.
Happy to answer any further questions.
Cheers Phil
Cheers Phil
