- Nov 8, 2011
- 1,678
Doesn't work but was fun making. My Rotary Chuck is missing the lever that operates the indexing feature so I set out to make one. I turned a shaft on my lathe then done some hocus pocus arithmetic and came up with 16 spacings on my collet chuck indexer I made (48 holes) I then put in a 60 deg. carbide insert bit on it's side and tried broaching it, after breaking the tip I decided to sleep on it. First thing this morning I conjured up plan B. I put a 60deg. HSS 1/4" lathe tool in a boring bar, mounted it my mill then chucked the shaft into my Hardinge indexable collet closer mounted on my mill, unfortunately it only has 24 holes so I arbitrarily used 12 spacings (2 on the indexer) Away I go & all finished appearing to be a workable part but once installed it bound.
2 things I did wrong for sure were I didn't center my cutter to the shaft & my arithmetic. It looked cool & was fun but back to the drawing board.
