- Aug 21, 2023
- 106
The Monaset is a Taiwanese made knock-off of the Cincinnati Monoset T&C Grinder. https://atrump.com/product/model-cm-a-atrump-tool-cutter-grinder-monaset/ The knock-off changed the second "O" to an "A". The folks that built Cincinnati Milling Machines designed and built the Monoset Tool and Cutter grinder from the 1940's into the 1980's. The complex and versatile grinder was added to compliment their #2 Model Cutter Grinder. And had only minor changes over its' lifespan. It was design to grind many operations in one setting. Sharpening most milling cutters. Or from bar stock it could make a cutter from scratch. Grind concave or convex radii. Make straight or tapered end mills with helical leads.. Automatically generate straight or tapered, right or left-hand infinitely variable spirals with a simple adjustment. Or can be used as an external or internal cylindrical grinder...
I have a full array of collets and wheel adapters
Attachments, cams, centers, guards, etc...
A precision six-jaw chuck that center's the work piece to less than a .001"
A Suburban 5" magnetic chuck for holding work pieces in the working head.
Rough machined Valve guide for my 1914 Cadillac that I ground to fit valve stem and press fit into head.
You can see the spiral action as the work head in moved. It's difficult to hold camera and turn handles.. but should get the idea..
