- Aug 19, 2014
- 76
With no football to occupy my time, I decided that I would put to use the piece of 1/4" HSS I had purchased from Enco. In the scrap pile, I found a piece of unknownium steel, some kind of mild steel in 3/4" rod. I turned it down to 5/8". Have you ground yourself a shear bit? Those dang things sure leave a slick finish. Anyway, I drilled and tapped one end for a set screw to hold the bit, cross drilled the 5/8" with something just under 1/4" and went to work with my smallest files to put some corners on the cross drilled hole. Getting it close to 1/4" square, I slid in the HSS 1/4" and tightened the set screw. Having it firmly held in the 5/8", I hit it with the grinder and bodged up what was my idea of a cutting edge. I tried it out on a short piece of stainless that I had picked up at the salvage yard, and I was pleasantly surprised that it worked as well as I heared it should. This is my second attempt using a boring bar, my first try was when I ground a cutting bit for opening up the hole on my 4 hole compound holddown. It may not be an earth shattering event for you CNC types, but for this old retired cop it felt pretty good. And now, one photo from my I-pad to document the event. John W
