- Oct 17, 2018
- 1,012
My cheap Vevor Chinesium x-axis feed motor has died for the second and last time. I've been researching making one and found one that I think I can make. I thought I would document it here and ask questions and post the answers in one place.
WHAT I'M MAKING
Here's the link to it:
It's a guy that goes by MrPragmaticLee.
He has another video that goes over the wiring for the speed control and motor:
Here's a follow-up video with the limit switches:
COMPONENTS
Power supply: Power supply #1
Motor: Motor #1
It has 10 kg-cm of torque, which is about 0.7 ft-lbs. Doesn't seem like enough. This is the style motor I'm using.
Maybe this one is better: Motor #2
70 kg-cm of torque, 5 lb-ft.
Speed Control: Speed Control #1
This is the style I'd like. It has a readout that gives the percentage.
Limit Switches: Limit Switch #1 these have 2 wires, which might mean they won't work for my application. Anyone know?
This style (I think). Note the 3 connectors. This is the kind used in the video:
QUESTIONS:
1. The motor he references is from a company that no longer exists. I can find similar ones, but need to know what RPM to get. I'm thinking about 200 max speed?
2. How much torque would I need to move the table while taking 0.025" cuts in steel?
3. The limit switches have 3 connectors. What wires go where? A more detailed wiring diagram would be helpful and appreciated.
4. The design uses 2 sockets. Are impact sockets easier to machine than the standard chrome ones? I might need to drill and tap a hole for a set screw in them.
More to follow! I'm in the preliminary design stages of the parts and layout for my mill. I will post when that's ready.
@markba633csi Do you have any insight?
WHAT I'M MAKING
COMPONENTS
Motor: Motor #1
QUESTIONS:
