I'm sure this has been done before but I'll give you my take on it. After trying the back gear route and running into what to me were insurmountable problems in lining up the motor with the gearbox I tried a new (to me) approach.
I used a small cast iron pulley (1.23 pitch diameter) on a Marathon 1800 rpm three phase 5hp inverter duty induction motor and simply connected it via V belts to the spindle. The motor is controlled by an Automation Direct GS2 VFD. Total cost was about $1,300.00. If anyone is interested I can give an exact figure.
Fired it up today and made some chips. Seems to work great, took some deep cuts on old axle stock and got a nice finish, Haven't done any threading. RPMs from 24 to 1800. What's not to like?
All that being said I am going to try to get the gearbox to work and may install it later.
