- Oct 12, 2023
- 88
Finally received the new to me Acra mill. Going over it I have a few questions.
Any idea where this braided wire should attach to?
Does anyone know the type of connector this is to help narrow my search for a new one? The one going into the motor wiring box is broken.
The mill came with a Newall DP700 DRO. The scales are metal rods, so I'm assuming they are magnetic. but, the mill is set up with X, Y, and Quill. There is no scale on the Z axis. I don't believe there is a way to add a fourth axis to this one. I do want a scale on the Z axis, so what do you guys think I should do? Should I scrap the quill scale, and look for the appropriately sized scale for the knee. Or do you think I should scrap the whole DRO system for something else. I know there are arguments for and against magnetic versus optical scales. I've looked at the TouchDRO and it looks like a really good option. The plan is to use this mill for firearms related machining, but could be used for other projects in the future to make money.
Lastly, this line for the power drawbar should just push back into that connector on the oiler, correct? The machine motor is stamped 2020, so with the machine being a max of four years old, do you think I should replace the regulator/oiler combo? it looks a little rough, but not sure what it's life span is.
Thanks for any help in advance.
