- Nov 16, 2012
- 5,596
Here's a small project to make a multi-purpose endmill holder. These can be used for all kinds of purposes. Here's the basic holder and in a short while, I'll make a cylindrical tool holder for it to hold a HSS bit. I'm making this today because I need to cut a gear later today.
The first part was made in the lathe but I forgot to snap a picture so, here we're just trimming the excess off in the bandsaw. Note the use of V-blocks for holding the piece. -Now you know what those are for...
Using the DRO, the centers were found. Here the weldon-flat has already been cut in the shank. That nice flat angle is used later on. I'm also milling a flat spot to prepare for boring a hole..
Hey wait... he's boring the hole off-center. Thanks for the heads-up but, yes, that is intentional. I want the hole off-center so the centerline of the HSS bit is in the center... You'll see... later today.
Now that we have that nice Weldon flat spot, it's used with a parallel block to line-up the part 90[SUP]o[/SUP] rotated so we can drill another hole.
Two more 3/8 holes were drilled in the ends coincident with the bored hole. There's also a holding screw on the side. Next, I will take a piece of round stock the same diameter of that hole then, cut it in half then, mill a 3/8 wide slot in the two halves. Then it can be inserted into the bored hole and clamped in there very securely (and yes, I need to trim those screws down a little bit).
This thing is made of 1045. I'll give it a test spin to see if it like it and if so, it will be put in the very big pile of metal waiting for heat treating. Time for lunch...
Ray
Ray
