I found one on eBay. It's called the Quadrill so it's aftermarket. Pretty cool but I assume it would add to the slop in the quill and not as precise as chucking directly. Hopefully someone will chime in.
R
I've never seen one but have seen the time when I could have used something like that to drill, counterbore, and tap multiple holes. What is the 4th head hidden behind the plastic guard?
i'd be the guy that'd come in around 300-350 for the unit ,
just because you know that there is one or more issues with the machine in general.
if it sounds and runs really good 350, if not 300
