- May 7, 2014
- 776
Hi Everyone, Hope everyone is doing well. Our Newb Shop of Dad & Son is so busy in learning mode that I'm just buried. Onle of my co-workers quit so not much time to play of late.
The last three eve's I have been trying to locate some TEMCO (not tempco) thermolyne /Barnstead/Thermo -Fisher (sp?) muffle furnace ceramic heating elements. (pics below).
Being a beginner the kid and I are learning that we have a muffle furnace. Old TEMCO (no "p") Internal size of 13/11/9 (?? close to this anyway)
All but 1 of the elements are bad and cracked and failed due to a crucible spill. 12Ohms on a top panel.
I guess this is a "What would you do" which I know I ask often here!
I can get some custom A-1 3/8 coils of proper length and coil- length and width run counts in proper Ohms but they are not cast into clay or anything. Just loose to hang myself??? $50 a piece.
How can I mount them to be functional even? Also, can I mold these into similar clay or ceramic plates on my own?
I can find some 12x11 top/bottom panels from Barnstead EBAY for $100 apiece but would need to get crafty and figure out the Ohm and current setups, but should be close. I loose a little space this way. I also see some 9x11 as well. I think I make get this up to all 4 panels for $400
or buy the pre made bare heater wire wound into runs and coils for $50 apiece.
Or do my own A-1 spool and try out some good winding skills and such.
Or hybrid - Buy the top bottom Barnsteads, and then buy the $50 hand wounds... Wire them in somehow? Assuming I can run current thru it all in some series or parallel config to get the Ohnm and overall watts correct.
Then get it all into a PID & contactor, safty close on/off switch etc... Man...... And I thought I was done after the Mill. LOL. So much fun though!
