Robo . Slow down and think out your jobs
Sorry. I didn't mean to give the impression I was in a rush to do anything.
Taking my time to think out the jobs is exactly what I am doing. I like to explore all the possibilities. I just watched the video by Joe Pie and thought that using a speciallized collet for a job like that does make a lot of sense. Especially if you plan on making a lot of the same part.
I'm just now tooling up an old Enco Lathe/Mill combo that I've had for some 20 years now. I haven't really used it lately. In fact, it was covered in rust due to the moisture it accumulated sitting in an unheated shop. Fortunately I caught it in time and it cleaned up really well.
Do you own a lathe and if so what spindle mount is it ?
The spindle mount really sucks, so be prepared for a long rant here.
Here's a photo of the naked spindle:
Not a real good picture, but maybe good enough to explain my rant.
I actually took the above photo as part of a project. I'm making a backing plate for a 4-jaw chuck. I have centers in everything because I'm actually getting the bolt pattern measurements transferred over to the new chuck backing plate. The chuck is held on by 3 M8 bols. I actually have a center punch in the tool holder I was using to get the bolt patter diameter. You can see there is a raised section in the middle of the spindle. That's the register for the chuck.
My big complaint here is that the original 3-jaw chuck was bolted on from the back side. The problem with this is that those bolts are extremely difficult to get at. There's barely any room to work between the spindle and the headstock. So it's a real pain to remove and replace the chuck. I'm currently in the process of changing this. Or at least I hope to. I'm going to drill three new holes in the spindle plate and thread them and bolt the chuck on from the chuck side. Making it much easier to remove and replace. I say that I hope to do this because I'm hoping that I can drill and tap this mounting plate. Hopefully it's not hardened. It doesn't appear to be. I cut into it with a file and it seemed to cut easily. So hopefully it will drill and tap easily too.
So I'm in the process of changing things up a bit. I like to remove the chuck when using the mill. And I also like to be able to swap back and forth between the 3-jaw and 4-jaw chucks. And I just recently bought a set of MT3 collets for it too which I would also like to use.
So I'm trying to modify this lathe and make it easier to change tooling on. The 3-jaw chuck that came with it is only 4". The new 4-jaw chuck I just bought is 6". So I'll have the larger chuck capacity too.
As far as using soft jaws I don't know what I would need to do to be able to do that. Both the chucks I have are equipped with hardened jaws and I have no idea where I would obtain soft jaws for them. Both chucks to have reversible jaws though. Well, the 3-jaw chuck actually has two sets of jaws. Both sets are hardened. I change the jaws often. Changing jaws is easy. Far easier than changing out the entire chuck. At least with those bolts behind the chuck. Hopefully I'll be able to drill and tap the spindle so I can bolt the chucks on from the front. That would make life a whole lot easier.
In fact, it beats me why anyone would have designed this thing the way it is. It must have been designed by a sadist. They must have figured that no one would ever want to change out the chuck. But like I say, I even like to remove the chuck when I use the milling head. So I'm taking this chuck off all the time.
I'll be trying to drill out the spindle plate here shortly. We'll see how that goes. I hope it's not a disaster. If it's hardened I won't be able to drill and tap it. Then I'll be stuck with having to bolt everything on from behind for the rest of my life. That would suck big time.
