- Feb 18, 2016
- 451
I finally finished the collet drawbar.
I wanted a set of collets for my lathe. I would have loved to use 5C collets but my lathe spindle bore isn't large enough. And it's already tapered MT3. I could have gone with ER collets, but I chose to go with MT3 instead. So I bought the following set of 12 collets from 1/8 to 3/4"
But then I needed to make a drawbar so I decided to use a handwheel off an old sewing machine I had laying around.
It turns out to work very well. Some concerns were voiced that this heavy sewing machine handwheel might loosen because of inertia when the lathe starts up or shuts off. But my lathe is sluggish enough on start up and stopping that this is not a concern. But I can see where that might be a problem on a lathe that jumps to life of stops real quick.
This was a pretty big project for me as I am just now tooling up. There were quite a few operations that I needed to learn about and set up for.
I started by cutting the threads for the actual collets. I did this with a standard die by hand. But it was tough to thread. This was made from an old axle of some sort and it seems to be pretty tough stuff. So on the right side I cut that threads using the lathe. That required making a thread-cutting tool bit and learning how to cut threads on the lathe. I posted that operation earlier.
I made the spacer in front of the handwheel again from a large gear axle. I drilled through it and tapped it to thread onto the shaft so that I could then lock it into place with a nut on either end. I had to then cut a shoulder to fit inside my lathe spindle to keep everything well-centered. Then on the handwheel side I turned it down for a press fitting into the handwheel. Unfortunately I got that a tad bit too large and when I pressed it in it cracked the handwheel. It doesn't seem to be a problem though because the outside ring of the handwheel didn't break so it still holds firmly to the shaft. Then on the back side I put a large washer and nut just to be sure the handhwheel can't work loose.
I have some left-over stock on the main shaft that I used when cutting the threads. I was originally going to cut that off and t rim the shaft down close to the nut that holds the handwheel on. But when I was trying it out I found that extra bit of shaft sticking out there a nice place to tap the collet loose so I decided to leave it as is.
It may not look like much, but this was a complicated build for me, and it works. That's the important part. Now I have collets! Yeah.
