MT tool post holder
Aukai
H-M Lifetime Diamond Member
Oct 4, 2016
7,164
What is the proper procedure for dialing in an MT drill holder on the tool post Seems to have a few answers :)
Indicate the face true while tightened , then indicate the tapered bore true . :)
Edit . Do this with an indicator mounted in your chuck Mike .
Say what,,,,? Can you say that slower? :)
:faint:, OK, I guess. LOL
The face of the holder has to be parallel to the chuck . Think about tramming a mill . After it is parallel , you then dial in bore on centerline of the chuck .
I'm starting to see a lot of indicating.
It's not really hard or time consuming . 2 operations .
1- make sure the drill is parallel to the machine ways ( this will be parallel to the chuck as well )
2- mount an indicator on a bar in your chuck . Set height and cross slide to bring bore in .
3- sit back , throw the power feed on and enjoy a beverage ( if the machine is big enough )
I'll believe it when I try it :cautious:
Lots of shortcuts to get close . Put a mag base on your ways , run it across the face of the toolholder to get 0-0 at each end , put a 1" or so bar in chuck and eyeball it close to the tapered bore . You'll get it within .010 or so , then just dial it in .
Use your EBI, you have one. Mount the MT holder, then look down your spindle bore, adjust until it's looks good. ;) (Eye Ball Indicator, only one works best)
(just joking of course, I'm bored)
  • Like
Reactions: Z2V
