I intend to use a MT#2 shell mill holder and a shell mill fitted to the spindle of my little Atalas MFC milling machine. I already have both the shell mill holder and the shell mill. I will be removing the tang from the holder followed by drilling then tapping the holder for a drawbar. Given the size of the shell mill I suspect that it will be pushing the upper limits of the work the machine is capable of performing. To that end I intend to make my first test cuts on aluminum once I get this all set up before moving on to cut steel.
When these machines were new Atlas sold a shell mill holder and shell mill that was supposed to screw onto the end of the spindle so I know the machine was intended to perform at least some functions with a shell mill. However, the original Atlas setup was screwed to the spindle and not working off of a MT#2 holder. I think that was likely because an adapter screwed to the end of the spindle was better equipped to handle the strain a shell mill would put on the spindle and prevent a taper from spinning in the spindle while in use. Also I believe the original Atlas would have better handled the side load issues related to these cutters that are rather large for such a small machine.
Getting to the point of my question; I anticipate having to really apply a lot of torque to the drawbar so that I can seat the taper in the spindle as firmly as possible. My fear is that I will seat the taper too tightly into the spindle and not be able to break it free once I want to remove it to change tooling. I thought about applying a thin coat of oil to the taper in the hope that it might help prevent the taper from effectively welding itself to the spindle. I have never oiled a taper prior to mounting it in any application I have ever done such as this. On the flip side I fear that oiling the taper will really do nothing but assure that the taper will spin in the spindle once a real load is applied to make a cut.
So does anyone here have any experience with this and have any wisdom or thoughts that might help me along as I make my way through this exercise? I would greatly appreciate anything others might be able to share or suggest. Thank you folks.
