- Oct 24, 2013
- 485
Hi folks from down in Trinidad, I'm an electronics guy (industrial and medical) with some machining skills and semi-reired. The workshop at home is split between electronics lab and machine shop. In the machine shop I have a Grizzly 9x20 Lathe (seriously modified), Grizzly Mini-Mill (4-axis CNC modified), 4x6 Bandsaw with flood, two CNC laser engravers, CNC plasma-jet cutting table, MIG, TIG and stick welders, small 3 in 1 bending brake and a manual plasma cutter. Of course the usual suspects, hydraulic press, drill presses, angle and bench grinders, etc.
Have had the mini-mill 15 years now and converted it to CNC and added the 4th axis in 2013. Always wanted a bigger, stiffer, more capable milling machine (Bridgeport), but of course financial and space restrictions. So, after long consideration I've decided to pull the trigger on a PM-935TS-3PH, DRO, Align X drive, Align Z drive, 5" Vise, R8 collet set, clamping kit, etc,etc.
So, I'm here to learn and also to share what little I know....... so the excitement begins. Here's what the shop looks like presently:
And, here's a glimpse of the electronics lab (yes,it's a mess right now):
