- Mar 26, 2014
- 1,572
Finally got around to moving my boring mill. When I store my RV I need to back it down past the mill to the back of the barn. It is very tight. So today was the day, I moved it two feet to the side. I put a 3 inch solid bar thru the headstock lifting holes and a two inch bar thru the tailstock lifting holes. Used a 50 ton Enerpac cylinder to lift each corner one at a time 3/4” off the floor and then used machinery skates blocked up under the bars. Once it was on the skates I just used a pry bar to inch it along.
The 3 inch bar was extremely heaving as it was 9’ long, I had to use a trolley jack to wiggle it thru the lifting holes. The rest was easy peasy. The mill weighs 21,500 pounds.I haven’t leveled it yet, maybe tomorrow as I wanted to get the RV away today.
Martin W
Martin W
