- Feb 24, 2019
- 957
A very common mistake.As long as it is in the atmosphere it is full, 100% because Air is a fluid. If it is in the vacuum of space, it will be empty...
Air is fluid, but
According to WebsterA very common mistake.
Air is fluid, butnotA fluid. Noun vs verb kind of thing
It's also an adjective but not a verb. So "Air is fluid" is a correct sentence, but it would be a 'noun v. adjective' kind of thing; but never a 'noun v. verb' kind of thing.According to Webster
noun
: a substance (such as a liquid or gas) tending to flow or conform to the outline of its container
The internet is awash with misinformation. Air is a fluid.A very common mistake.
Air is fluid, butnotA fluid. Noun vs verb kind of thing.
noun
I should have said adverb/adjective/noun sort of thing.
The fluid movement of the ballet dancer provided the illusion of a mermaid.
Tom
In the real world AIR is A gaseous Fluid and if you get it cold enough it is a liquid fluid. Everyone thinks of fluid as a liquid only but it is not. SO, Air is a fluid, it has mass which is why, at sea level, the atmospheric pressure is 14.7 PSI (which can be +/- dependent upon temperature); and, why water boils at 212 degrees F at sea level and cooler as altitude increases (provided your not in a pressurized cylinder at atmosphere).A very common mistake.
I think they are all full of HOT AIR.All this talk about air just blows my mind.
Sent from my SM-T500 using Tapatalk
