- Sep 22, 2024
- 13
Hi all, before I remove the sand cast model steam flywheel I'm working on I wanted to ponder what the best next way to proceed might be.
What I have is a aluminum sand cast flywheel that I center drilled using the mini mill then tapped for a 1/4 by 20 bolt. The bold is threaded into the flywheel and a pad chucked into a 4 jaw. I need to remove the bolt and re-center the hole and enlarge it to 5/16
My original idea was to flip it around to use the machined face and mount it to the face plate but how do I dial that in? The clamps would be in the way and how to make slight adjustments?
Did not really want to machine the back as I like the rough look but I could machine at least some of the back then re-mount in the 4 jaw. I did leave the draft angle on the outer rim as I thought it looked interesting but if I machine it parallel I could flip it around and use the machined face in the 4 jaw.
what to do? Thanks, Dale
