- Nov 8, 2011
- 1,678
This is the adapter plate I'm making for my stepper motor to mount on my gantry, the hole pattern was slightly different and I also need to make a coupling/adapter to connect the gear reduction shaft to the shaft in my stepper. Here's what I've done so far.
I had no way to drill a hole as big as I needed or accurately so I laid out the hole & chucked the stock in my 4 jaw. As you all know I'm a bit tooling challenged right now and a bit green. I racked my brain on how I was gonna mill this piece with what I had on hand, then I remembered seeing a picture on here of a rectangular piece chucked in a 4 jaw and the light came on. To center the piece I scribed an X from corner to corner then I put my live center in my tail stock & slid it up close to the piece and started centering it with the 4 jaw. After centering it I put my drill chuck in my tail stock along with a silver Deming 1" drill and bored a hole to start my cutter in. I really had to Jerry rig something up and made several changes of tooling & setups til I ended up with the big tool holder.
I couldn't cut the hole all the way through to the full diameter because of the reversed jaws were in the way on the back side. I brought the hole to dimension/diameter now I'm gonna mount it on my Burke mill & fly cut the back side till the hole is all the way through (Basically a back rake operation) I'll do that tomorrow night and post pics, I have some video also.
