mounting a collet chuck to a backing plate
irishwoodsman
Nov 19, 2011
966
this is my big question, how far does the step on the backing plate need to be to slide inside of chuck, right now there is about a 1/8 of step but my chuck has room for about 3/8ths Thanks guys :biggrin:Mac
That is sufficient to register the chuck. I would leave it like that, rather than making it deeper, unless there are runout issues. Even then I'd just turn the first 1/8" under, and move in another 1/8" for a new register.
thanks Tony, i wasnt for sure so i fig i better ask lol, going to have some time on the backing plate its about 3 inches bigger than the chuck so there is def going to be some chips or should i say grit lol:biggrin:Mac
Then may I suggest a trepan tool sop you end up with a usable cast iron ring?
Good excuse to make one, then. It's simply a grooving tool with radiused clearance to plunge in the face of the part and cut a groove through it. Kind of a sideways part-off tool.
Hi Mac
Out of interest, is that for 5C collets? What size od is the closer plate? A friend of mine is looking around at collet closers. The type your pic shows looks like it would be easyer for mounting, and with out the tube , and handwheel to deal with.
