I came across a second Craftsman 101.21400 lathe awhile back and am looking for a good base to mount it on. I came across a slab of steel that measures about 2x3 feet and is 1" thick. My question is do you think it would improve the machine enough to make it worthwhile to mount it to this heavy piece of steel, or should I just go with a lighter base? I have some 2" maple butcher block that I could also use. As a plus the plate looks to be ground so it is flat and would certainly be more stable than wood.
