- Jul 19, 2020
- 91
Not really today, but over the last week or so. Did all the machining, then had a local welder come over and weld it to the trailer. Has 3 2" hitch receivers on the back of the trailer. End result will be the center one is just for lifting/lowering, the outboard receivers carry the load. Here's a couple pictures of the parts before
and after assembly:
Next is making the lift mechanism. That will be telescoping square tubing, Acme thread and nuts, thrust bearings and seals. The goal is to lower the motorcycle carrier to ground level, roll the bike on, tie it down, raise it slightly above the outboard receivers using a cordless driver, slide in the outboard supports, lower the carrier and insert a couple pins. Weight will be about 500 lbs total.
and after assembly:
