here's a similar motor, just as an illustration.
disclaimer: i have no connection with the company, distributor or manufacturer of the motors
click the link below
http://electricmotors.guidestobuy.c...fc-c-face-leeson-electric-metric-motor-192027
it is not a direct replacement, but very similar. the shaft protrusion is only 23mm.
modification by extending the shaft could be possible with a little forethought.
with a little more research, i can get a little closer.
- - - Updated - - -
just out of curiosity why are you replacing the motor?
unless you have a direct short inside the motor,
i would consider replacing the bearings if there is only a noise issue and otherwise electrically ok
3 phase motors generally last forever unless shorted or corroded badly
i'm not suggesting that anyone else attempt, but i have disassembled new motors for the field windings and installed the old special specification rotor into the new field windings and made old dead stuff breathe again with 100% success and survival rate.
i once installed a used 7.5 hp 213t rotor into a new 215t field housing, payed $450 for the new motor and transplanted the windings to avoid buying a $2500 dollar factory spec motor.
that piece of equipment works 7 days a week and has been doing so for 6 years now.
Boy am i glad i don't listen to know it all's, who tell me it can't be done!!!!
My 7.5 hp RPC was produced form 2 failed baldor motors frankensteined into the abomination that efficiently runs any piece of equipment i wish to start up.
it will grudgingly fire off a 10 hp motor unloaded in about 2 1/2 rotor rotations
