- Sep 23, 2015
- 31
When I turn the lathe on the motor just hums. If I spin the pully it takes off just fine and runs fine until I shut it off and have to start again. It's a craftsman 1/3 hp 110. Should I replace the motor or is there a way to fix the way it starts? It doesn't matter if there is tension on the belts or not. Just won't start turning on it's own. A quick spin of the hand and it's off to the races. It does bother me a bit. All I want to do is turn on the switch and work. I can't say I like playing wheel of fortune when I machine. Any suggestions welcome. Thanks.
