I have an Atlas 618, probably model 101.21400 [unsure because ID plate is missing]. I'm just starting to clean/review this machine.
The motor I got with it is not the motor listed in the manual. They are 1/2, 1/3, and 3/4 hp; mine is 1 hp. Other info from my motor:
Dayton AC Induction Motor
1725 rpm
Model 6k223c
Hz: 60
Duty: cont
It seems to have various configurations with 115 or 220 v. I am not well versed in electrical matters so this is a bit of a mystery.
The Atlas 618 manual shows a Countershaft Assembly with motor mounted directly behind the headstock, with a bracket, hanger, and various pulleys. My setup is different. My countershaft bracket is not the same, and the motor is a good 13" behind the countershaft. This all seems to work but I'm not sure it's a good setup. Also, it requires more space. I will have to get a new table to accomodate this L shaped arrangement.
Does anyone have experience with mounting the motor so far behind the lathe? Any suggestions?
Thanks,
Darla
1725 rpm
Model 6k223c
Hz: 60
Duty: cont
Thanks,
Darla
