More noob questions
Bamban
Jul 13, 2014
1,054
I got the codes on the indexable inserts figured out, lots of information out there. What I can't find is the code breakdown of the different holders, like SCLCR, SCLCL, TAR, TAL, TBR, TBL, TE,.....etc.. guessing the last digit stands for left and right, could not decipher the others. Is there a published code sheet like in the inserts as to what all these mean?
TIA
Page 731 in Machinerys Handbook 25th ed. Is there something particular you are looking for?
I looked it up and found this:
Toolholder ANSI Designation Chart
MWLNR164D
Insert Holding
Insert Shape
Toolholder Style
Insert Relief L
Hand
Shank Size
Insert IC
Length
M = clamp and lock pin
C = 80 deg. diamond
A = 0º side cutting, straight shank
N = 0º
R = right hand
5 = 5/16 x 5/16
1.2 = 5/32"
A = 4"
P = lock pin only
D = 55 deg. diamond
B = 15º side cutting, straight shank
A = 3º
L = left hand
6 = 3/8 x 3/8
1.5 = 3/16"
B = 4.5"
C = clamp only
K = paralellogram
C = 0º end cutting, straight shank
B = 5º
N = neutral
8 = 1/2 x 1/2
1.8 = 7/32"
C = 5"
S = screw lock only
L = rectangle
D = 45º side cutting, straight shank
C = 7º
10 = 5/8 x 5/8
2 = 1/4"
D = 6"
R = round
F = 0º end cutting, offset shank
P = 11º
12 = 3/4 x 3/4
2.5 = 5/16"
E = 7"
S = square
G = 0º side cutting, offset shank
D = 15º
16 = 1 x 1
3 = 3/8"
F = 8"
T = triangle
J = -3º side cutting, offset shank
E = 20º
85 = 1 1/4 x 1
4 = 1/2"
M = 4"
V = 35 deg. diamond
K = 15º end cutting, offset shank
F = 25º
20 = 1 1/4 x 1 1/4
5 = 5/8"
N = 4.5"
W = trigon
L = 5º side & end cut, offset shank
G = 30º
24 = 1 1/2 x 1 1/2
6 = 3/4"
P = 5"
M = 40º side cutting, straight shank
86 = 1 1/2 x 1
8 = 1"
R = 6"
N = 27º side cutting, straight shank
32 = 2 x 2
10 = 1 1/4"
S = 7"
R = 15º side cutting, offset shank
T = 8"
S = 45º side cutting, offset shank
T = 30º side cutting, offset shank
U = -3º end cutting, offset shank
V = 17.5º side cut, straight shank
Y = 50º side cutting,
straight shank
To the responders,
Thank you, I appreciate the help.
