The last item on my to-do list for the weekend was to drill & install roll pins in the anvil plates for the HF 20T hydraulic press. To accommodate stacking the plates, I counterbored the drilled holes to allow clearance for the extending roll pins.
Before inserting the pins, I opted to countersink the drilled holes and . . . it occurred to me that I really don’t know of any guidelines or standard practices for the selection and use of countersinks.
In my tool cache, I now have an ample collection of countersinks, zero flute, 1 flute, multiple flutes, diameters from ¼” to over 1”, 82* & 90*, carbide and HSS.
Asking the forum members:
What criteria governs which type of countersink to use, and at what rpm?
Are certain types of countersinks not good for use on steel?
Should cutting oil be used?
What would the reasons be for choosing a multi-flute over a 1-flute countersink?
Can/should a 1 flute countersink be used with a hand drill?
