Spent some time messing with the lathe today. For some reason, it doesn't seem to run smoothly--kind of like it is going out of gear. It runs good for a few seconds, then starts to "hitch". Everything seems tight, but I'm not totally confident that the motor is mounted perfect.
I notice that the big lever you pull (not sure what it's called) to get it out of gear does not lock down, it slips up out of the catch no matter how I adjust it.
Next, the motor does not seem to pivot down enough to tension the belt on the small drive pulley (large one seems fine) the picture is with the motor all the way down.
Last thing--there doesn't seem to be a whole lot of clearance between the motor mount and the spindle. Motor is all the way down in the picture.
Thanks for any thoughts!
Regards,
Michael
Regards,
Michael
