- Mar 20, 2014
- 418
My project this week was to organise the draw of loose collets under my lathe (in-between conference video calls with my colleagues at work, troubleshooting iffy server environments and trying to get UNIX box access for myself to monitor stuff)
I came up with this - modular, print as many as you like, with label slots to allow identification of the collet. I thought the tolerances on the bowties that keep the trays together might have been too sloppy, but they seem to be spot on - tight enough that they don't need glue, loose enough that you can easily assemble or disassemble the trays into larger or smaller units.
Modular Machinists Organiser Tray System by GreatOldOne
UPDATED 22/06/20Trays to hold standard 5C & ER32 collets plus plain trays of various lengths - modular, print as many as you need and keep them together with the bowties. Each rack has a label slot so you can put a size label in for easy collet finding (so long as you put the collets back where...
www.thingiverse.com
