I want to start using Hougen type annular cutters in my mill.
The shank on the typical annular cutter doesn't readily accommodate a drill chuck or a collet, due to the two flats on the cutter shank for set screws. I've been successful using a 3/4in collet but I'd rather not worry about slippage, etc.
The only ready made tool that I've found on the web is by Accusize Tool for $66, but the reviews are terrible.
Seems like an economical alternative would be to modify a 3/4in end mill holder to accommodate the cutter. The mods required would be to remove the beveled nose of the end mill holder, and add a set screw 90 degrees from the existing set screw.
I searched the forum on this subject a found a reference to one guy that was successful doing this but he didn't elaborate on how he did it. If the end mill holders are hardened, and I'd need to purchase expensive specialized tools to do this, it would make the prospect less tantalizing.
Another alternative would be to make an adapter with a straight shank on one end, for a collet, and a precision bore on the other, with two set screws, for the annular cutter. Could probably be made from CRS.
Can anyone advise?
Can anyone advise?
