- Jul 14, 2017
- 2,455
I've already made this steady rest to work on my lathe couple of mounts ago and posted on PM forum, but wanted to post this may help someone here, it seams lots of lathes are being sold without the accessories and steady rest seams to be hardest to find, what i've done is found a much bigger steady rest of a bigger lathe, surprisingly with the same lathe way grove but was about 80mm taller, so disassembled it and cut the bottom 75 mm with an angle grinder, not having a mill had to take it to a near by machine shop, they index it from the split flange, then milled it flat and square, and cut a new groove that locates it to lathe bed, also relieved it to clear the carriage, painted, reassembled and put it to work, hope this helps someone and you like the pictures.
