Model number ?
Scruffy
Jun 5, 2013
549
Where do I find the model number of a cream color jet band saw has cylinder down feed, coolant and cast base and over arm.
Also does anyone know anything about this vertical saw.
Thanks Ron
I used to have one of these saws. It's a generic sold by many different companies and does the job.
I replaced all the bearings in the guides and lubed the gearbox. The feed is a simple hydraulic valve and pretty much bullet proof.
Only problem was the coolant pump is electric and burned out and plastic tank cracked. Deemed too expensive to replace.
Bought a Johnson at an auction and sold the Jet, just because..
Yep the jet is your standard 7x12 everyone sells. Don't recognize the vertical one.
