- Dec 21, 2018
- 48
I recently just finished making the MLA boring and facing head kit. I know some people on here have made MLA kits before, but if you have not heard of them you should check out their website. They have casted kits mostly for small lathes like the South Bend 9", but also have some other kits like a die filing machine.
http://mlatoolbox.com/index.html
As usual this kit from Andy was awesome, with fully detailed instructions and a letter with some comments on the instructions/some things to do differently.
I made a video of the assembly, so you can see how everything goes together. I also uploaded a few still shots. You will notice in one of the photos, a plate bolted to the top of the main body. I accidentally misread the blueprint and machined too much off the top of the body. I bolted the plate on top and machined everything to the correct dimensions so I did not have to scrap the body.
This was a very fun kit, and I highly recommend it. It's a cheap and fun way to get a facing head, which can usually be a very expensive tool. The hardest part was probably making the gear. Without a dividing head, I think it would be a little difficult to make, but that doesn't mean it can't be done. Everything else was pretty straightforward.
Sent from my Pixel 2 using Tapatalk
