I'm considering a lathe upgrade here, at the moment my favorite candidate is the PM-1440GT 3 phase. I want a VFD and don't have 3 phase power, so the lathe will not be usable at all until the VFD is working. The recommended VFD is the Hitachi WJ200-022SF.
So the goal is to plan a VFD configuration for initially operating in the simplest way, with minimal intrusion into the lathe's factory wiring (and easily restored to stock factory condition). Delay any "non essential extra feature" options to separate future upgrade(s) to keep the initial setup as simple as possible (KISS). Carefully document the wiring and changes for maintenance and future upgrades.
I've looked at a lot of other folks plans here and elsewhere on the web and gone through most of the Hitachi manual. This is the simplest variation I have come up with thus far.
Version A
I'm interested in comments and feedback.
Thanks in advance.
Version A
- Physically locate the VFD where it can be accessed to set speed and adjust programming easily. Use an enclosure with a hole so wiring is protected but front panel is out where it can be accessed without risk to hazardous voltages. The input circuit breaker can be similarly mounted in this same box.
- Install the power cord and plug to bring 220V and ground to the appropriately rated circuit breaker, then to the lathe (on the appropriate two of the three input busses) and to the VFD power inputs.
- Run motor power wires from the VFD motor outputs to the motor, disconnecting and insulating the original motor power wires.
- Program the VFD for the motor ratings and perform basic testing as directed in the VFD manual to verify the VFD and motor wiring.
- From the 24VAC coils of the forward and reverse motor direction contactors parallel a pair of small 24VAC coil control relays, the output contacts are wired to the appropriate VFD run (forward and reverse) inputs. These modules can be mounted in the VFD enclosure as well to minimize changes in the lathe itself.
- Program the remaining desired parameters into the VFD for basic operation.
Thanks in advance.
