My goal is to have the cross slide gib on my 7x14 mini lathe tight for rigidity and implement a bearing to make the slide smooth to operate, and maybe get rid of a little backlash in the process.
Is there more to it than hogging out the bushing to house the bearing(s)? I'm not sure I even see exactly how a bearing can make a difference if the gib is tight. I tend to overcomplicate things. Note that I don't want to increase the travel with a longer bushing which also requires other mods.
1. Has anyone in this forum done this mod on a mini lathe and does it really work?
2. How does the bearing overcome the tight gib to slide easily?
3. Are thrust needle bearings a good option?
If I can do this mod then I'll photograph each step and write up a detailed tutorial to make it easier for others.
