- Aug 22, 2012
- 4,273
A good friend of mine has a ubiquitous Chinese mini lathe.
He wanted to mount a 5" 4 jaw chuck to it but the existing back plate is too small and also an integral part of the spindle.
A bit of thinking and we decided to make a large ring and weld it to the original back plate.
First part was finding a large enough chunk of metal, none available so join some up
Yep, thats large enough
Full penetration welding from both sides one bead at a time in an effort to control distortion.
It seemed to work so chop all the corners off
add a drive pin and turn round
then face off both sides
bore out to fit the outer dia of the spindle plate
