Hi,
Hope everyone is well and safe.
I watch KA videos where the he does threading using a tail stock die holder and always says he puts the lathe into back-gear. I have concluded that back-gear is a high-torque, yet very low speed setting apparently very useful for threading using a die. His standard size lathe offers this setting of course.
As an owner of a mini lathe, this setting is not available (presently) and it got me thinking; is there a modification that could be made to obtain high-torque and very low speed for threading in the aforementioned manner?
I have made several attempts at trying to thread a long part using a 10-32 die only to find later on that the thread resembles a belly dancer, swinging from one side to the other of the shaft rather than be a nice straight threaded shaft. I know what causes this; uneven pressure on the die holder while I manually cut the thread.
Sure, I can slow down my lathe to a similar speed but as soon as any cutting force is applied, it stops and the fault light comes on. Ugh!
Being able to create the part on the lathe using a tail-stock die holder would end my frustrations.
So, what say you all, is there anything that can be done to a mini lathe to obtain this?
Mike
Mike
