I've got an old busted milwaukee mag-drill with that uses a dovetail to raise/lower as opposed to a round column like a drill press which makes me think that it would be more accurate and more rigid than a drill press. That and being designed to attach itself horizontally to the side of a ship or an oil rig derrick while some salty seaman or roughneck hangs on it and plows away without mercy for an entire shift makes me think it's more cut out for the side-load of milling. Recent posts about mounting small drill presses on lathes has got me thinking that resurrecting this old mag-drill as a lathe milling attachment might be worth my time. Only draw-back is that it uses a Morse #3 taper for the chuck. I was planning to make an endmill holder tool instead of holding endmills with the Jacobs chuck, but I would still have to use that morse taper, and I've heard that milling in such a scenario can cause the chuck (or endmill holder in this case) to fall out. So is there any trick to making that not happen? I was thinking of getting the tool good and seated in the spindle, then drill a hole through and put a spring pin in. Would be "good enough"? Or possibly some sort of draw bar solution?
Also any input about the feasibility or methods of mounting the mag drill to the lathe are appreciated. I'm planning right now to remove the "mag" part (base) and mount the remainder on the base plate of my tailstock (tailstock removed). So on one side of the lathe you have, well, a lathe, and on the other side you have a mill.
